Does ha17741 equal ua741?
xmli1976
Full Member level 1
Full Member level 1
ha17741
I've bought a ha17741 op amp,but what the circuit I am about to buildup require a ua741.Can ha17741 be used to buildup the circuit instead of ua741?
And I found that the circuit schematic connect the ua741's v- to ground,and v+ to 9v power supply.I don't know if it's correct?
I'm a newbie.
Thank you !
ha17741 output range
xmli1976 said:
I've bought a ha17741 op amp,but what the circuit I am about to buildup require a ua741. Can ha17741 be used to buildup the circuit instead of ua741?
Yes, HA17741 is pin compatible to uA741.
DigChip.com ( https://www.digchip.com/ )
Cross reference search
Possible equivalence(s) found for: ha17741
ha17741 -> LM741N-8
ha17741 -> UA741T
ha17741 -> IR3741
xm1976 said:
And I found that the circuit schematic connect the ua741's v- to ground, and v+ to 9v power supply. I don't know if it's correct?
It depends on the input range of op amp in your design. If V+ is connected to 9V and V- is connected to GND, the input range of the op amp should be (slightly) higher than 0V and (few volts) lower than +9V because uA741 is not an rail-to-rail input/output op amp.
op amp 741 ha17741
Thank you,I've looked up the datasheets of the two 741s.
Their most parameters and electric characteristics are same.
I asked this question because there are some difference between the datesheets of the 741.Such as DC gain,ha17741 is 106db, ua741 is 200v/mv,they use different unit,and I don't know what kind of circumstance under which the gain value get.
I think since they are all 741,the difference must be little.So they must be compatible.
Thank you again!
