ckkkkk
Junior Member level 2
How to convert accelerometer data into G with the ADXL345 digital accelerometer
Am totally new to electronics and the datasheet is very confusing to me, so can anyone please guide me through the specification of the accelerometer? So that i can have a better understanding on the accelerometer and to be able to convert the accelerometer data into G.
X-axis Y-axis Z-axis -28 -26 218 These are the readings i get from the accelerometer with a +-2g range
This is the datasheet for the ADXL345 digital accelerometer [1]: https://www.analog.com/media/en/technical-documentation/data-sheets/ADXL345.pdf
These are the code.
HTML:
import smbus
import time
# Get I2C bus
bus = smbus.SMBus(1)
# ADXL345 address, 0x53(83)
# Select bandwidth rate register, 0x2C(44)
# 0x0A(10) Normal mode, Output data rate = 100 Hz
bus.write_byte_data(0x53, 0x2C, 0x0A)
# Select power control register, 0x2D(45)
# 0x08(08) Auto Sleep disable
bus.write_byte_data(0x53, 0x2D, 0x08)
# Select data format register, 0x31(49)
# 0x08(08) Self test disabled, 4-wire interface
# Full resolution, Range = +/-2g
bus.write_byte_data(0x53, 0x31, 0x08)
time.sleep(0.5)
# Read data back from 0x32(50), 2 bytes
# X-Axis LSB, X-Axis MSB
data0 = bus.read_byte_data(0x53, 0x32)
data1 = bus.read_byte_data(0x53, 0x33)
# Convert the data to 10-bits
xAccl = ((data1 & 0x03) * 256) + data0
if xAccl > 511 :
xAccl -= 1024
# Read data back from 0x34(52), 2 bytes
# Y-Axis LSB, Y-Axis MSB
data0 = bus.read_byte_data(0x53, 0x34)
data1 = bus.read_byte_data(0x53, 0x35)
yAccl = ((data1 & 0x03) * 256) + data0
if yAccl > 511 :
yAccl -= 1024
# Read data back from 0x36(54), 2 bytes
# Z-Axis LSB, Z-Axis MSB
data0 = bus.read_byte_data(0x53, 0x36)
data1 = bus.read_byte_data(0x53, 0x37)
zAccl = ((data1 & 0x03) * 256) + data0
if zAccl > 511 :
zAccl -= 1024
# Output data to screen
print ("Acceleration in X-Axis : %d" %xAccl)
print ("Acceleration in Y-Axis : %d" %yAccl)
print ("Acceleration in Z-Axis : %d" %zAccl)
These are the code.
