Does Dev Cpp compiler has bugs in debugger?
neocool
Member level 4
Member level 4
dev cpp bulgarian
HI,
I am using the last version of Dev Cpp compiler right now.
When allocating memory in one of my functions, during the debugging process I get an error "An Access violation (segmentation fault)". The function calls 2 times without a problem and then gives me the error.
However, when I complile file, there's no problem - it runs completely fine and allocates all I want.
There are some problems I wanted to fix, but I cannot use the debugger because of the above.
Could this be a buggy debugger problem? ;)
Eh, this takes too much time
Thanks
dev-cpp and memory
Segmentation Fault:
You can blame the compiler/linker/debugger for allot of errors. But in 99.99% of the cases it's your own stupid mistake ;-) (And yes I know!)
Probably you're trying to access memory that doesn't belong to you!
Possibly you're trying to access memory already free-ed.
Pointers are powerfull but also difficult to debug ;-)
