Does BJT area related with Current?
zahrein
Full Member level 2
Full Member level 2
reverse saturation current bjt
Guyz,
While i was deisgning the op-amp 741 BJT using the cadence spectre, i have to put the value of the area. The values are range from 1 to 16 for a different transistor.
What is the relation with current? Is it bigger area has bigger Is(saturation current)? Or else?
Thank you
bipolar transistor reverse saturation current
The current approximately scales wth area. Because of the voltage drop across the base region, most of the current flows on the edge of the base-emitter junction.
current equations for bjt
Does it means the bigger the area, the higher the current (Ic)?
bjt reverse saturation current
It means the current is larger for a given base-emitter voltage applied to the transistor.
complete collector current equation bjt
Recall the collector current equation (Gray & Meyer)
Consider the effect on your poles as there will be a larger parasitic capacitance in the junctions. Unless you want the high current (or as multiples in Bandgap), do not use excessively big device.
emitter area saturation current of bjt
Actually the Is (the reverse saturation current) depends on the area of the emitter and width of the base. In say, CMOS processes, we can play around with the areas of the emitter to get higher currents because Ic=Is.exp(VBE/Vt).
bjt current equation
I think your equation is wrong, there should have been an area factor.
it has the option to write the device multiplier.
Well the equation for the current in the bipolar device is right, the current equation in a bipolar device is given by Ic = Is .exp(VBE/Vt)
where Is = qADn ni^2/Wb Na
where q - electronic charge
A - Area of the emitter
Dn - diffusion constant for electrons
ni - Intrinsic Carrier concentration
Wb - Width of the base
Na - Acceptor Ion Concentration in the base
