Does bigger VCO gain mean bigger output jitter?
Analog_starter
Full Member level 1
About VCO gain
Hi all,
The VCO gain varies hugely under different corners, such as tt, ss, ff, low temp, high temp, low power, and high power. What is the practical value that I can put it into the system level simulation?
If I want to design a VCO with 500M~1G tuning range, 1.8V power supply. What is the best VCO gain? It can reach the 1G frequency under the tt, room temp, 1.8V, but failed in ss,low temp,and low vdd. While meet the output under the worst case, The VCO gain is so huge in normal or fast corner (about > 1.5G/V). How can I solve this conflict?
Does the bigger VCO gain mean the bigger output jitter?
I am really puzzled with them.
Thanks & Best Regards
Analog_starter
Re: About VCO gain
The VCO gain is decided by your low pass filter voltage range.
What kind of CAP do you use?
I think maybe you can try to use the SS corner to design the VCO first then extend
to other corners.
The larger VCO gain is, the worse jitter performance has.
Re: About VCO gain
In my experience, It will have at least 3 times difference in FF and ss corners ( include the bias, cap...corners).
What is your VCO construction?
Re: About VCO gain
Hi huanchou,
I use MOS CAP in order to reduce die size.
But when it meets the output under the SS corner , The VCO gain is very huge in tt or ff corner. What is the practical VCO gain value that I can put it into the system level simulation?
Hi simonkuo,
It is just a three-stages ring oscillator. And how do you deal with the 3 times difference?
Analog_starter
Re: About VCO gain
The practice VCO gain is decided by your selected foundry.
Some foundries usually tune their process to TT or FF corner but some not.
But due to the chips need to be packaged, the VCO gain are usually smaller than your simulation results.
So you should analyze your WAT data, to check which coener they deviate to.
Re: About VCO gain
If I select the foundry of TSMC, I will check the TT and FF corners.
If I select the foundry of hynix, I will check the SS and TT corners.
If I select the foundry of UMC, I will check the SS and TT corners.
for your reference.
BR.
Re: About VCO gain
Does it mean nobody can always promise that his(or her) VCO can work at every process corner, especially for high frequency output?
Analog_starter
Re: About VCO gain
It will take the tract-off between your circuit margin and your performance.
If you want to design the larger circuit margin, you will lose the more circuit peformance.
If you want to fit all of the process corners, you have to design the large VCO gain, but its jitter performance will worse.
Re: About VCO gain
Thank you all!
Analog_starter
