Does any industry have a 100VDC power bus?
T
treez
Newbie level 1
Hello,
I cannot understand why these xenon flash beacons are designed to run off an input voltage of 10-100VDC.
Surely very very few industrys uses a power bus of 100VDC?
I woudl have thought 60VDC was the maximum likely to be used, otherwise they would just use 230VAC or 120VAC mains... or even 3 phase mains (415VAC)?
Telecom is 48V, and some applications impose voltage
deratings of 2X when reliability is needed "by the book".
10V meanwhile is a discharged automotive battery.
Probably just trying to cover as many apps with one
design, as practical.
Reactions: treez
    T
thanks.....the thing is that above 60V and the cost of solutions goes up dramatically...because there are few monolithic led drivers, IC's etc which can handle above 60V.
