Does an inductor can be used as RF choke?
STOIKOV
Full Member level 4
Full Member level 4
inductor as RF choke
Commercially available inductors can be used as RF chokes ?
Re: inductor as RF choke
You have to watch out for the DC current rating. When filtering DC you need to look for the series resistance which will cause heating and voltage drop. You also have to look for the reduction of the inductance (when there is some core material other than air or an insulating support) from being biased of the center of the BH curve by the DC current.
    STOIKOV
One important thing is self resonace frequency (SRF). It has to be less than the operating frequency otherwise your inductor will become a capacitor.
    STOIKOV
My friend I think you are wrong when you want to use with the inductor as RFChoke you must take inductor with SRF bigger then operating freq.
But if I am wrong please correct me!!!
David
    STOIKOV
Yes, we have all used inductors as "RF chokes" on things like bias lines, etc.
The inductor would have to be used in a frequency range below its SRF, otherwise at resonance it would have no "filtering effect".
However, I do think it would be confusing to use the terms "inductor" and "RF Choke" interchangeably. When I want an "RF choke", I want something that is a LOSSY inductor (ie has part inductance and part resistance in its series impedance). The lossy nature is what allows you to form wideband rf blocking without fear of resonance with shunt bias capacitors! If you look at a typical "ferrite bead" data sheet, you will see that is has considerable resistive loss.
If you used high Q inductors as an "RF Chokes" with impunity, you could get in trouble in some cases with a parasitic bandpass filter formed in your bias network--such as when you have two series RF Chokes with a DC bias line length of around λ/2 between them.
    STOIKOV
I've been told about this RF choke, what do you think for DC supply applications ?
What you need is a ferrite bead. They come in forms with multiple holes with the wire winding several turns through the holes.
    STOIKOV
