Documents about timing concepts (on negative setup and hold time)
praneshcn
Member level 5
Member level 5
can someone suggest some presentations on timing concepts with examples
Re: timing concepts
Hi..
Lot of timing concepts discussed in this board. Check those posts.
Thanks
Reactions: rajudanaraddi
    rajudanaraddi
    V
timing concepts
Dear praneshcn,
please be more precise, so we can help you accurately.
Cheers,
Master_PicEngineer.
Re: timing concepts
tanx for the reply.
in particular i would to like to have some material on negative setup and hold time. hw it is advantageous and also the concept of virtual clock and its role in setting input and output delay.
thanks in advance.
Re: timing concepts
I would like to get these notes. Can you help?
Re: timing concepts
u can refer this pdf..
Re: timing concepts
Hope this PPT gives idea about timing analysis
