Do we use Channels for Routing in between the Std Cell Rows ?
Ikon
Member level 1
In SOC Encounter when we see the Floorplanning /placement View there will be Standard Cell Rows ( Every Alternate Row Flipped because to accompany for VSS and VDD).
Do we use Channels for Routing in between the Std Cell Rows or it is completely Channel_less Routing?
Re: Routing
channels are like guide for routing. they made routing easy for tools like SOCencouter etc..
there are channel-less routing capable tools also, like magma, but takes more time for time for routing but core utilization will be more.
Re: Routing
IMHO all modern routers including nanoroute in SOC are channelless ones. It is true, that old channel routers were fast. .13 and .09um technologies need a flexible routers which are supporting all their specific DRules
Re: Routing
So
Routing in SOC Encounter is a Channel-less routing. So routing is done entirely on OTC Over the Cell Routing .Right.
Can we or Is there any option/command to introduce channels in the routing ? if required .
