Do we need a PFC frontend for SMPS that draws 30W ?
eem2am
Banned
We are in Maryland and we have an SMPS which is rated at 60W, and therefore it has a PFC front end.
However, the 60W output only occurs for one second when 4 solonoids are operated.
-after that, the power draw never goes above 30W.
Its in a shower unit so the (normally-closed) solonoids only get activated once per day, per person, typically.
-after being activated, the solonoids draw the low level holding current.
-so should we really need the PFC stage?
Re: PFC for SMPS?
None of the computers made in China have PFC in their power sources; I have tested 10+ noname computers, some older than others. And PSU is rated between 250..400W.
None of the power supply for LCD (even branded ones) have PFC!!!
The same with most notebooks.
So I would say: no, the PFC is not really needed.
Re: PFC for SMPS?
No, you don't have to have a PFC front end. One of my designs is a 200W motor drive that meets all CE requirements without a PFC front end. It did require a relatively large line reactor to meet some of the requirements though.
