Do I need a Logic Analyzer?
radnusmar
Member level 1
Member level 1
Chennai
I have to measure a signal of 17mS of a single wire communication. The period of each signal is about 206uS within which Data 1 pulses for 51 us or Data 0 pulses for 103us.
The minimum interval I have in the Digital Storage Oscilloscope is 1mS and Maximum no of Intervals of DSO is 2500 for recording.
Do I need a logic analyzer?
Number of samples (2500) is fine, if your DSO can handle a sample rate of (say) 10usec.
By 1mS minimum interval, do you mean one division on the screen is 1msec?
I'd be surprised if you need a logic analyzer, this is a slow signal, enough for most scope speeds, and enough
samples capacity.
Sample rate specified my the Manufacturer is 1GSa/s.
1 mS is the minimum interval of the Oscilloscope. Total No of Frames is 2500.
and the Interval Specifies Interval between frames.
I need to measure the width of the logic lines. Between a time of 206uS.
I think you've kind-of answered the question yourself with the figures.
The oscilloscope is fine, no need for logic analyzer.
