psurya1994
Member level 5
The DMM I am using has some sort of loose connection, only the right side two seven segment displays work properly. Some of the led's in the middle 7 segment display works sometimes. The others on the left, work only if the dmm is subjected to some kind of pressure, all of them work. How can i make all the 7 segment displays work properly?
