gavin168
Junior Member level 3
DLL question
I am designing a DLL project, working range is 40MHz~240MHz, but the duty cycle of input clock is 30%~70%.
I plan to do:
1), in order to lock correctly, the delay will be forced to below 1 period when initial. so i plan to reset the vcntrl to be VDD?
2), for the the working range, I plan to use self_biasing to make the charge pump?
3), I preferred to use the differential delay cell, but the input clock is single ended clock with bad duty cycle, so plan to use invert chain to be the VCDL, the vcntrl is connected to a regulated buffer to control the delay.
Hope anyone give me some suggestion. and is there anything should be concerned? Thank you.
I plan to do:
