boylesg
- Joined
- Jul 15, 2012
- Messages
- 1,023
- Helped
- 5
- Reputation
- 10
- Reaction score
- 6
- Trophy points
- 1,318
- Location
- Epping, Victoria, Australia
- Activity points
- 11,697
Made myself a bobbin out of a piece of copper pipe and two PVC disks that fit over the end. This then fits into a ferrite core of a tv flyback transfomer.
I have seen some examples of these where people put a layer of transparency sheet in between each layer of wire, however I have found this ends up taking up a lot of space with multiple layers in the limited space I have available on the bobbin.
And unless you include insulation layers OR emerse the whole thing in oil after you wind it then you get corona problems.
But the problem with emersing the transformer in oil is that you are unlikely to get rid of ALL the air between the wire strands, unless perhaps you put the transformer under oil in a vacuum.
Others use araldite or some other epoxy as they are winding, but that is painful.
So I came up with another idea and am trying it.
I am not bothering to wind methodically since I am using quite fine gauge magnet wire (not sure what it is) and I will probably get more than enough turns even without methodical winding.
But what I am doing is smearing petroleum jelly over the windings every now and then and excluding the air while I am winding.
What do you experts think?
