DIY a Compact RC Switch
Chimicron
Newbie
Newbie level 3
Good day~all,
I have made a compact RC switch circuit,which built around the LM358 comparator reacts to a 50Hz PWM signal with a pulse width of around 1-2ms. If the reference voltage ( at pin2 of LM358 ) fixed by the 10K oitebtuineter is lower than the filtered signal voltage (at pin 3 of IC1), the comparator output goes high, relay driver BC547 (T1) is switched on and the 5V relay (RL1) works. The 100K reistor ( R5) provides small hysteresis to prevent the comparator from responding to every minor wavering in the voltage on the non-inverting input (pin 2) of the comparator. The aim I bluit this circuit is to control the on/off of lighting on radio control projects.
Well,Comparing with the above circuit,the only differences are that
1).The relay driver(T1) I used is BC547A instead of BC547. This is the BC547A PDF.
2).My circuit has a 20K pot and it will not work,I am having a hard time figuring out the pin 2 input,giving a negative voltage.
Can anyone here help me?
Best regards~
The circuit should work but the LM358 isn't very good when working from low voltages, using a real comparator would help.
The PWM amplitude will be halved by the divider of R1/R2 so if you are feeding a 5V PWM signal it will never go higher than 2.5V and for example, at 50% PWM ratio will only be 1.25V. Adjusting P1 sets the voltage at which the output at pin 1 should switch state, when the voltage at pin 3 goes higher than the voltage at pin 2, pin 1 should go high and turn the relay on.
I suspect your problem is you are using an op-amp that doesn't work very well at low voltages, you should really use a comparator instead as they are designed to switch abruptly instead of passing through a linear region.
Brian.
The description is a bit confusing.
* I see nothing related to RC in your circuit.
* I see nothing related to PWM or 50Hz. I guess it will work with much higher frequency like 10kHz as well as DC input.
I miss an error description:
it will not work
What do you expect it to do? What does it do instead?
Negative voltage? I see no (need for) negative voltage.
Debug: report us the voltages at pins 1, 2, 3 of IC1
What´s the nominal relay coil current?
Improvement: Put a filter / stabilizing capacitor at pin2 of IC1.
Klaus
The input common mode range for this OpAmp is limited -
Then there is the possible phase inversion problem with the LM358 -
Audio guys report unless output loaded with 1 mA load or greater severe crossover distortion.
Translate DC issues when operated as a comparator, eg. non linear response under the right
conditions affect clean desired comparator operation. Maybe a better RRIO OpAmp should
be in the works for the design.....
Regards, Dana.
Brian.
Thanks for your help, I figured out that it should be the BC547 that doesn't work well with more than 50mA.
Yes 50mA is getting up there for a BC547 if you don't have 3-5mA of base current, i.e. 1k drive.
--- Updated ---
The inputs of the LM358 can go to gnd ( -0.3V in fact ) but they cannot go near +Vcc as explained above ...
