muruga86
Member level 3
- Joined
- Mar 26, 2005
- Messages
- 54
- Helped
- 2
- Reputation
- 4
- Reaction score
- 1
- Trophy points
- 1,288
- Location
- Chennai, India
- Activity points
- 1,927
how to divide a circle cicumferance with respect to n equidistant parallel secants?
the problem is as follows..........
i have a circle of diameter 138 inches when calulating its circumferance comes to 433 inches. 32 eqidistant lines or secants of which are parallel to each other with 3 inch gap pass through the circle each intercesting the circle at two places on both sides. of the 32 lines 16 lines are on the oneside of the center of circle and the remaining on the another side. the center of the circle is half way between the 16 and 17 lines (i.e 1.5 inch). now my aim is to divide the circumferance of the circle such that it is more or less eqidistant with respect to secants cutting it. i can't do the genearal way of dividing the circumferance of circle by 360 and use because at both end of the parallel lines i.e 1 and 32 lines the arc width is more between the 3 inch gap than at the center i.e 16 and 17 lines.
given attached the image of the question.......
for non members of the forum the image is attached below,
can any one give me a solution?
thanks in advance
thanks in advance
