swarupdoshi
Newbie level 3
I tried searching for a fast divider design where the LSB is generated first. I am not sure if such an algorithm or design has been implemented or not.
Say if the design has 16-bit divisor and dividend and the system only requires the last 6 lsb's then if the LSB's are generated first then the division would take less number of iterations compared to MSB first.
If any one has come across such design please do write here.
Thanks for the attention.
SD
SD
