Divider==Counter? How to divide by different "N"?
knack
Member level 2
Member level 2
Austria
Hi there!
Is it alway could stated that Counter = Divider and Divider = Counter??
I specially mean in PLL way back from VCO... the "÷N" block, is it counter or divider??
It should be multimodulus right?? for an application like a freq. Synthesizer!
Well, practically speaking, how can a counter or a divider be changed??
I assume that they'll change it using "clear" and "reset" etc. signals, but this will have different delays for divided signals...
Anybody understanding "how a multimodulus divider work" can explain it to me??
Cheers,
-- Knack
You can think of a divider as a counter that pulses a single bit output 'high' whenever the count value is 0x0. Then you build a counter that counts up (or down) to (from) a programmable value, wraps and keeps counting. Whenever it wraps, the output is pulsed high for a cycle. This will give you a multi-modulus N or M divider. For a post divider this approach is generally not sufficient because of the highly distorted duty cycle at the output.
    knack
Re: Divider==Counter? How to divide by different "N&amp
Yeah.. You're great!
But practically, how can i get a contineous range of values of N or M values that divider divide by them?
Can you provide sample simple example of such a divider? that may divide for example by values from 180-280 with constant unity step!.. is there something practically like that??
Thnx again :)
--Knack
In verilog for 16 bit divider (1-65536):
input CLK;
input [15:0] N;
output DIV_CLK;
reg DIV_CLK;
reg [15:0] counter;
always @(posedge CLK) begin
if(counter == N) counter <= 16'h0000;
else counter <= counter + 1'b1;
DIV_CLK <= (counter == 16'h0000);
end
    knack
eternal_nan, How can i thank u!
But i don't have license to verilog, i have one to Verilog-A only!!! Your code can't be applied to it..
Moreover, i hope to get a block diagram to the divider or a Flip-Flop level schematic or something like that..
Thnx anyway
-- Knack
