Divide by 3 or Divide by n Counter
ramana_k22
Newbie level 6
Newbie level 6
divide by n counter
Hi all,
I want to know how to design a divide by 3 counter with 50% duty cycle.
Ramana
divide-by-n counter
1. simply use a 2 bit synchronous johnson counter with truth table as 00/01/11....( initial as 11 / Q1, Q0 / Q0 as LSB )
2. a independent T-FF whose clock come from CK*Q1*Q0 + /CK*/Q1*Q0, the output of T-FF is required
3. If full synchronous is required, more complex one similar as about
divide by 3 frequency divider
Use DCM module which I know is in Xilinx.
BRMadhukar
divide by 3 counter
Design a counter asynchromous will be easier using 2 JK flip flops
Use 2 JK flip flops Use the out put of LSB and MSB through a nand gate to trigger the clear pin of the flip flops to restart counting
synchronous divide by 10 counter
try this
design of divide by 3 counter
just go through this!!!
all the best
what is a divide by n counter
I'll try 2 sum up the steps:
1. Generate two clocks at half the desired frequency with a quadrature-phase relationship (constant 90° phase difference between the two clocks).
2. Generate the output frequency by exclusive-ORing the two waveforms together. 'coz of the constant 90° phase offset, only one transition occurs at a time on the input of the exclusive-OR gate.
Reference taken from the file attached...
It gives description of majority type of clock dividers..
Hope it helps u...
tut..
  • clock_dividers_made_easy.pdf
design a divide-by-7 counter
my design[/img]
divide by 3 design
Try to use a divide-by-two frequency divider to generate a signal with half the frequency of the original. And then use an AND Gate to sum up the original and the divided signal.
n counter
Use a 3bit counter
Re: design of divide by 3 counter
all the best
Good Document Thanks
Re: divide by 3 design
That will give a divide by 2 with 33.33% duty cycle.
Reactions: lmvishwa
    lmvishwa
    V
Use 2 D-FFs, say D1 and D2. both operate on same CLK. And D2=Q1. D1= (Q1 Nand Q2).
Double the frequency and divide by 6. Multiplying can be done with a RC circuit and a XOR gate. Divide by 6 with 3 flip-flops and a XOR gate.
This circuit will give a 50% duty cycle.
It can be done with the following circuit.
