tom324
Full Member level 1
https://distcc.samba.org/
distcc is a program to distribute compilation of C or C++ code across
several machines on a network. distcc should always generate the same
results as a local compile, is simple to install and use, and is often
two or more times faster than a local compile.
Unlike other distributed build systems, distcc does not require all
machines to share a filesystem, have synchronized clocks, or to have
the same libraries or header files installed. Machines can be running
different operating systems, as long as they have compatible binary
formats or cross-compilers.
<snip>
<snip>
