amirke
Member level 5
I want to designt a fast ethernet line (1 Gigabit)
My SOC (xilinx Zynq) has to be connected to a PHY then to magnetics and finally to a RJ45 connector
SOC-------------PHY-----------Magnetics---------RJ45
|---distance 1---|---distance 2---|---distance 3---|
I know that thumb rule talks about 25 mm of distance between each component
But I need to place the RJ45 connector far 50-100cm from the SOC.
So what is the recommendation for all the distances between the components (PHY, Magnetics, RJ45) ?
max distance 1 = ?
max distance 2 = ?
max distance 3 = ?
Thanks
max distance 1 = ?
max distance 2 = ?
max distance 3 = ?
Thanks
