dissipation factor of film capacitors
eem2am
Banned
hello,
how can you tell what is the dissipation factor of these capacitors at 100KHz,?
https://www.farnell.com/datasheets/18677.pdf
...on page 12, the datasheet only says the dissipation factor at 10KHz or 1KHz,....this is not much use since my SMPS switches at 58100Hz.
i wish to use the 330nF, 400V one close up to the power switch loop, so as i don't draw so much ripple current from the electrolytic cap.
