bagusdj
Member level 3
hey guys, im trying to make a project but most of i do here is not been taught when i was in class. so i gather information from internet.
i interface analog sensor to mcu to display it in lcd. the adc is 8 bits do it will display 0-255. i want to display each of that binary that multiplied by 0.39. what i have to change? also i want to add ppm as the unit. i just dont know it because i dont have any lecture about this before and no experience neither. this is the code using keil C compiler:
// Program to interface LDR using ADC 0808. The output of LDR is displayed on LCD. Controller interrupt is used to generate the clock for driving ADC 0808.
#include<reg52.h>
sbit ale=P1^0; //address latch enable
sbit oe=P1^3; //output enable
sbit sc=P1^1; //start conversion
sbit eoc=P1^2; //end of conversion
sbit clk=P1^7; // clock
sbit ADD_A=P1^4; // Address pins for selecting input channels.
sbit ADD_B=P1^5;
sbit ADD_C=P1^6;
sfr lcd_data_pin=0xA0; //P2 port
sbit rs=P3^7;
sbit rw=P3^1;
sbit en=P3^6;
sfr input_port=0x80; //P0 port
unsigned int bitvalue,decimal_value,key,left_value,value,number,ascii1,ascii2,ascii3,flag,key1;
void timer0() interrupt 1 // Function to generate clock of frequency 500KHZ using Timer 0 interrupt.
clk=~clk;
void delay(unsigned int count) // Function to provide time delay in msec.
int i,j;
for(i=0;i<count;i++)
for(j=0;j<1275;j++);
void lcd_command(unsigned char comm) //Function to send command to LCD.
lcd_data_pin=comm;
en=1;
rs=0;
rw=0;
delay(10);
en=0;
void lcd_data(unsigned char disp) //Function to send data to LCD.
lcd_data_pin=disp;
en=1;
rs=1;
rw=0;
delay(10);
en=0;
lcd_dataa(unsigned char *disp) //Function to send string data to LCD.
int x;
for(x=0;disp[x]!=0;x++)
lcd_data(disp[x]);
void lcd_ini() //Function to inisialize the LCD
lcd_command(0x38);
delay(5);
lcd_command(0x0F);
delay(5);
lcd_command(0x80); //Force cursor to blink at line 1 positon 0
delay(5);
void BCD() // Binary to decimal conversion to send the data to LCD
key1++;
key=0;
flag=0;
number=input_port;
value=number%10;
number=number/10;
ascii1=value+48;
if(number!=0)
value=number%10;
number=number/10;
ascii2=value+48;
flag=1;
else
ascii2=48;
flag=1;
if(number!=0)
value=number%10;
number=number/10;
ascii3=value+48;
key=2;
else
ascii3=48;
key=2;
if(key==2)
lcd_data(ascii3);
if(flag==1)
lcd_data(ascii2);
lcd_data(ascii1);
if(key1==3)
key1=0;
ascii3=0;
ascii2=0;
ascii1=0;
delay(10);
void adc() //Function to drive ADC
while(1)
ADD_C=0; // Selecting input channel 2 using address lines
ADD_B=0;
ADD_A=1;
delay(2);
ale=1;
delay(2);
sc=1;
delay(1);
ale=0;
delay(1);
sc=0;
while(eoc==1);
while(eoc==0);
oe=1;
BCD();
lcd_command(0x88);
delay(2);
oe=0;
void main()
eoc=1;
ale=0;
oe=0;
sc=0;
key1=0;
TMOD=0x02; //timer0 setting for generating clock of 500KHz using interrupt enable mode.
TH0=0xFD;
IE=0x82;
TR0=1;
lcd_ini();
lcd_dataa("value : ");
lcd_command(0x88);
adc();
