display Rds(M1) in Hspice
Full Member level 4
Full Member level 4
hspice rds on
when I simulate only single MOSFET, I want to display Rds(m1) as Vgs increased.
but I can't see that
Clearly, I can display Gds(m1) and this result is surely correct.
.PRINT gdso(m1)
but next command is not working properly. But I cannot tell the reason.
.PRINT RDS=par('1/gdso(m1)')
this graph curve is so odd, not correct.
is there anyone who can tell me the reason?
thanks.
hspice rds
Hi.
Can you tell me why do you think that's not correct? and by the way have you make a DC sweep? if yes, still you think the output curve is not correct? please send your circuit and results, then I can answer better.
Regards,
EZT
    020170
Mm...
maybe I get hold of the wrong end of the stick.
thanks.
