[SOLVED] Display FPC connector
ArticCynda
Advanced Member level 1
It seems like an 31 way 0.5 mm pitch FPC.
On farnell i find 4 pieces with that configuration.
Klaus
Thanks for your reaction Klaus! With these settings I also found 4 on Farnell, but they all look quite different. May I assume that the display can be mated with all 4? Or are there other parameters to consider?
In farnell you find datasheets to each connector. Lucky you ther are only 4 hits.
Look for fpc thickness, fpc width and if you want the connectinn on top or bottom side of the connector.
Klaus
