[PIC] Display DS1307 RTC data PIC18F24K40
ajit_nayak87
Member level 5
Member level 5
I have PIC18F24k40 with DS1307 RTC device. here is sample code i have shared here. I am facing actual while displaying parameter.
i am setting value of MIN_SET & SEC_SET =0X40 in decimal . if i use below instruction it properly increment . but in Run mode while displaying ,it display hexadecimal value 0X28
Temp1= sec & 0x0f;Temp2= sec>> 4;
LEDBuffer_1[0] = DISPTABLE[Temp1];
LEDBuffer_1[1] = DISPTABLE[Temp2];
Temp3 = min & 0x0f;Temp4= min >> 4;
LEDBuffer_1[2] = DISPTABLE[Temp3];
LEDBuffer_1[3] = DISPTABLE[Temp4];
If i change below value it will display hexadecimal value after 40. if i set MIN_SET & SEC_SET =0X00 then properly increment. But for MIN_SET & SEC_SET=0X40
min paramter shows 0X40 and sec parameter display for 56 it shows 38
what are changes need to made to display actual value. Somewhere i need to convert bcd to decimal and decimal to Bcd conversion
my code is code.txt file
  • code.txt
I assume you are confusing the value representations.
So either you set
* 0X40 --> which is hex. "0x" means it is a value represented as HEX.
* or you set 40 in decimal (without "0x")
...but you can´t set "0x40" in decimal.
So I assume you set 40 in decimal... this is 0x28 in HEX. There is no difference in the code nor in the stored data.
40 (decimal) = 0x28 (HEX) = 0b00101000 (binary) = "(" (ASCII) . There is no difference in the value, it´s just another representation.
The difference is how "you" see it. or how you tell the print function to display it.
Klaus
Here is my code where i could able to change RTC value. I have share part of code. DATE_TIME_SET_ADD function where i am changing the RTC
date and time in programming mode.
when i come out of programming mode means if (pgm_run == 0) if i short (RTC_Write ==1) i.e port pin then only it write.
for value 0 to 30it wont any difference showing but after 30 it display in hex. where i am making wrong here.
how i need to correct. weather i need to convert bcd to decimal or decimal to bcd here.
signed char Hour_ON1;
signed char Min_ON1;
signed char Hour_OFF1;
signed char MIN_OFF1;
signed char YEAR_SET = 20;
unsigned char MONTH_SET = 1;
unsigned char Day_SET = 1;
unsigned char HOUR_SET = 0;
unsigned char MIN_SET = 0;
unsigned char SEC_SET = 0;
unsigned char WK_DAY_SET = 0;
unsigned char RLY_PATTERN = 0;
unsigned char BLINKFLAG = 0;
void DATE_TIME_SET_ADD() {
    //Setting Date and time
    if ((Rly_No == 10) && (Comb_No == 1)) {
        Day_SET++;
        if (Day_SET > 31) {
            Day_SET = 1;
        LEDBuffer_1[1] = DISPTABLE[Day_SET / 10];
        LEDBuffer_1[0] = DISPTABLE[Day_SET % 10];
    } else if ((Rly_No == 10) && (Comb_No == 2)) {
        MONTH_SET++;
        if (MONTH_SET > 12) {
            MONTH_SET = 1;
        LEDBuffer_1[1] = DISPTABLE[MONTH_SET / 10];
        LEDBuffer_1[0] = DISPTABLE[MONTH_SET % 10];
    } else if ((Rly_No == 10) && (Comb_No == 3)) {
        YEAR_SET++;
        if (YEAR_SET > 99) {
            YEAR_SET = 0;
        LEDBuffer_1[1] = DISPTABLE[YEAR_SET / 10];
        LEDBuffer_1[0] = DISPTABLE[YEAR_SET % 10];
    } else if ((Rly_No == 10) && (Comb_No == 4)) {
        WK_DAY_SET++;
        if (WK_DAY_SET > 60) {
            WK_DAY_SET = 1;
        LEDBuffer_1[1] = DISPTABLE[WK_DAY_SET / 10];
        LEDBuffer_1[0] = DISPTABLE[WK_DAY_SET % 10];
    } else if ((Rly_No == 10) && (Comb_No == 5)) {
        HOUR_SET++;
        if (HOUR_SET > 24) {
            WK_DAY_SET = 0;
        LEDBuffer_1[1] = DISPTABLE[HOUR_SET / 10];
        LEDBuffer_1[0] = DISPTABLE[HOUR_SET % 10];
    } else if ((Rly_No == 10) && (Comb_No == 6)) {
        MIN_SET++;
        if (MIN_SET > 59) {
            MIN_SET = 0;
        LEDBuffer_1[1] = DISPTABLE[MIN_SET / 10];
        LEDBuffer_1[0] = DISPTABLE[MIN_SET % 10];
    } else if ((Rly_No == 10) && (Comb_No == 7)) {
        SEC_SET++;
        if (SEC_SET > 59) {
            SEC_SET = 0;
        LEDBuffer_1[1] = DISPTABLE[SEC_SET / 10];
        LEDBuffer_1[0] = DISPTABLE[SEC_SET % 10];
// Display_RTC_Clock
void Display_RTC_Clock() {
    unsigned char Index = 0, Temp_Runner = 0, Temp1;
    unsigned char Temp2;
    unsigned char Temp3;
    unsigned char Temp4;
    Temp1 = sec & 0x0f;
    Temp2 = sec >> 4;
    Temp3 = min & 0x0f;
    Temp4 = min >> 4;
    LEDBuffer_1[0] = DISPTABLE[22]; // display R
void main(void) {
    // Initialize the device
    SYSTEM_Initialize();
    I2C1_Initialize();
    I2C1_Write1ByteRegister(0x68, 0x00, 0x30);
    I2C1_Write1ByteRegister(0x68, 0x01, 0x30);
    I2C1_Write1ByteRegister(0x68, 0x02, 0x05);
    I2C1_Write1ByteRegister(0x68, 0x03, 0x01);
    I2C1_Write1ByteRegister(0x68, 0x04, 0x02);
    I2C1_Write1ByteRegister(0x68, 0x05, 0x03);
    I2C1_Write1ByteRegister(0x68, 0x06, 0x10);
    DgtSel = 1;
    GIE = 1;
    while (1) {
        if (pgm_run == 1) {
            __delay_ms(10);
            start = 0;
            if (Pgm_Mode_Entry == 0) {
                Pgm_Mode_Cnng_Over = 0;
                Update_Rly_Power_on(0x00);
                Rly_No = 1;
                Comb_No = 1;
                BLINKSEGMENT = 0;
                SELECTPRESS = 0;
                BLINKFLAG = 0;
                run_Mode_Entry = 0;
                RLY_PATTERN = 0;
                Eprom_reads();
                Pgm_Mode_Entry = 1;
            KeyCheck();
        } else if (pgm_run == 0) {
            if (RTC_Write == 1) {
          I2C1_Write1ByteRegister(0x68, 0x00, SEC_SET);
          I2C1_Write1ByteRegister(0x68, 0x01, MIN_SET);
          I2C1_Write1ByteRegister(0x68, 0x02, HOUR_SET);
          I2C1_Write1ByteRegister(0x68, 0x03, WK_DAY_SET);
          I2C1_Write1ByteRegister(0x68, 0x04, Day_SET);
          I2C1_Write1ByteRegister(0x68, 0x05, MONTH_SET);
          I2C1_Write1ByteRegister(0x68, 0x06, YEAR_SET);
        sec = I2C1_Read1ByteRegister(0x68, 0x00);
        min = I2C1_Read1ByteRegister(0x68, 0x01);
        Hour = I2C1_Read1ByteRegister(0x68, 0x02);
        Display_RTC_Clock();
The clock works in BCD mode.
Read about BCD.
Example, minutes:
Hex / decimal value of HEX / time representation
0x00 = 0 = 0 minutes
Up to
0x09 = 9 = 9 minutes
(Not allowed: 0x0A = 10 to 0x0F = 15, because no valid BCD)
0x10 = 17 = 10 minutes
Up to
0x19 = 25 = 19 minutes
(Not allowed: 0x1A = 26 to 0x1F = 31, because no valid BCD)
0x20 = 32 = 20 minutes
Up to
0x29 = 41 = 29 minutes
(Not allowed: 0x2A = 42 to 0x2F = 47, because no valid BCD)
You see the decimal values are confusing.
Better human readable is the HEX view. But in each HEX nibble (4bits) only values of 0...9 are allowed. A to F is not allowed.
Klaus
