Disabling PDF printing
i_am_here
Newbie level 5
Newbie level 5
Is there any way to print PDF documents in which authors have disabled the printing option.? Any solution
Re: PDF printing
rancohen_2000 wrote :
the authors uses password for that . you can disable it easy...
use the Advanced Password Recovery PDF
But to disable this password using software that u metion , require a original password. so Is there any alternative?
PDF printing
You can only remove the edit password if you can open the pdf file. It seems that the PDF file has been encrypted for open. Only brute-force way can remove it.
Re: PDF printing
the pdf security isn't so hard to break. send me your file and i will see what i can do..
PDF printing
see - Ghostscript, Ghostview and GSview
PDF printing
use some software like cajviewer
Re: PDF printing
