Ahmad Edi Saputra
Junior Member level 2
Dear All
i need help with these 2 case
1. Can I disable modem reset (DTR pulse) while installing driver usb to serial port? so when i plug usb to serial, pin DTR will always remain low (or high), default instaling usb serial while generate about 3 or 4 pulse on pin DTR.
2. Can I detect usb event plugged/unlpug with java? if not, what programming language should i use?
