Direct port accessing in XP
alunaro
Member level 5
Member level 5
Another world
direct port access xp
Hello
I need accessing to send some commands to keyboard via keyb controller (BIOS port 60, 64...). Is there any way to direct port access in win xp? I'm using VC.
I don't know it w32 api can help, or if i need 3rd party apis... I have low experience using ports directly in XP (really nothing :D )
Thank u
u can use api command or if u like to acces directly , u shoud write a driver and with this driver u can access the lpt port.
There is a bunch of parallel port information on the following web page, including freeware and shareware drivers for WinXP and WinNT. You may be able to adapt some of it to your keyboard needs:
One of the shareware programs looks like it might work for your application:
Hello,
I need accesing to device ports like keyboard controller...
I was reading some papers and... well.. the only way is make a custom driver or using one like porttalk...
