Direct connection of FPGA (spartan-6) to HDMI connector
aminpix
Full Member level 2
Full Member level 2
I am designing a Spartan-6 board with a HDMI output.
I have noticed in all Xilinx eval boards use a retimer or HDMI interface to connect FPGA to HDMI connector. When I go through spartan datasheet I see spartan itself has TMDS_33 output pin.
my questions are:
1- Can I connect spartan-6 (XC6SLX25) to the HDMI directly?
2- What is the job of some interfaces chips such as TMDS141 (in Atlys board)?
3- If I have to use interface chip, I may use TMDS181 ( which is still not obsolete). Is it convert differential signals to TMDS?
I personally doubt it.
For sure it depends on what features the XC6SLX25 provides and what video and audio standards you want to transmit.
Generated test picture / still picture / moving video...
But it will be a challenge to generate Gigabits/s of digital video data stream.
and for sure you need a fast enough memory to
I don´t know.
But if I wanted to know I´d first read the datasheet.
Klaus
LaTeX Commands Quick-Menu:
