Diode's junction capacitance related to frequency
snvl0228
Junior Member level 1
I'm designing PSFB converter. so, I'm using SiC diode.
It's switching frequency is 100kHz.
If I change frequency 100kHz to 20kHz, diode's junction capacitance will decrease? or increase?
Capacitance "should" not depend on frequency
but your -measurement of it- may, as Rs is in
there and could affect "simpleminded"
current-for-applied-AC-voltage methods. A
VNA / s-param pull would give you the
component values for Cj and Rs.
Capacitance increases with power rating as Rs decreases. SiC material has a much lower RsC=Tau material time constant but other factors affect Tau (Figure of Merit) such as PIV which raises Rs or RdsOn in FETs or Rce in BJT's or IGBT's. There isn't a precise constant yet there is a consistent trend for diodes with these variables of semi- material, geometry and power rating or chip size.
However frequency is a parameter that does not change the capacitance structure of the insulation between conductors hence the value does not significantly change in this range.
Thanks. It helped me a lot.
Write your reply...
LaTeX Commands Quick-Menu:
