diode required.. 5 amp, PIV should be above 70..
aniket433
Junior Member level 2
aniket433,
So? You need a part. What should the folks in this forum do about it?
Ratch
why this post anyway what you want us to do
i found this in google
try to google it out
Is this to be used on High Frequency rectification or what? What is the actual use of it? Only then can be suggested for the part number.
i want to use these diodes for rectification purpose...
The easiest way to find what you're looking for is to search in the catalog of an online store. e.g. See this list of diodes at RS. You can specify voltage and current ratings etc, and choose how to sort the results.
try googling there you will hit a bus load of them
then you can choose between the available alternatives here
Rectification of normal AC or High frequency? A normal diode won't work on High frequency purposes. Please clarify.
