Tyler Grey
Junior Member level 1
Story : I transformed a ATX computer PSU into a benchtop PSU and while I was using it, I pulled off 6~8A from the -12V rail which is rated at 0.3A
After 2~3 seconds it shut down with some popping sound. I took a look inside it, and could identify that the FR154 fast recovery diode was broken down in half due to overcurrent.
And btw, the PSU shuts itself down in less than 1 second anytime I try to turn it off and on again. I Guess some kind of safety circuit is activated.
Q1. Can I replace the FR154 diode with a FR155 diode?? If so, would it just have a higher peak voltage or would the higher recovery time cause it to overheat and break again?
(DATASHEET : https://pdf1.alldatasheet.com/datasheet-pdf/view/288350/SYNSEMI/FR154.html)
Q2. What other components would or could have been broken due to overcurrent?? I don't think the diode itself is causing it to shut down itself.
Q3. I'm thinking of replacing some capacitors which I pulled off first in order to take a look at the diode. If I replace the capacitors, Higher voltage limit wouldn't make any problem right??(Just being sure.)
