vaisakh
Newbie level 3
- Joined
- Nov 1, 2010
- Messages
- 4
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- KERALA,INDIA
- Activity points
- 1,305
consider a series circuit consisting of a sinusoidal ac source a diode and an inductor....usually in inductive circuits I lags V by 90'......but with a diode in series to inductor the current wave form gets clamped ie circuit behaves as if a virtual dc current source exists.....wat is the physical reason....if found confusing pls refer a power electronics text for a diode rectifier with inductive load and kindly explain the current waveform.....i need physical explanation
