[SOLVED] Diode performance specification
Zak28
Advanced Member level 2
Is a fast recovery diodes maximum reverse recovery time the same speed during its max forward current & Repetitive peak reverse voltage or is it much longer than what was specified?
usually specified on the data sheet, e.g. 125 degC and If = 30A, and dIf/dt = 100A/us ( quite slow ) etc
you have to read all the fine print carefully...
Reactions: Zak28
    Zak28
Most small SMT diodes dont have any charts for recovery time or di/dt.
Which is telling you that if those are critical parameters for you, you shouldn’t be using that particular device. It’s like asking what the 0 to 60 acceleration for a Smart Car is. If you’re asking that question, it’s the wrong car. (FYI, it’s double digits).
Reactions: Zak28
    Zak28
if you are using a small diode in a switching ckt and the data sheet does not give switching information, then you use it at your own risk, other batches may differ significantly from the unique one you try in a single prototype.
For a more guaranteed outcome you have to buy from a manufacturer who does list these parameters, e.g. ST.com
Reactions: Zak28
    Zak28
