eem2am
Banned
Hello,
I am writing with regard to the MOSFET gate drive pin on the LT1241 PWM controller.
Is a diode needed to be connected to it.?
In an offline SMPS , it is said to be necessary to put a Schottky diode at the gate drive pin of any PWM controller……..as seen here by D5……….
Schottky (here D5) at gate drive output pin .
(https://i35.tinypic.com/2j2aoo6.jpg)
To collaborate
On page 306 of Raymond Mack’s book “Demystifying switching power supplies” (2005) an MBR170 schottky diode (here D1) is clearly seen at the gate drive output pin of the LT1241 PWM controller.
(The topology is a one-transistor-forward-converter).
The explanation for this diode is given on page 309, at the top of page, it says …..
“This diode prevents transient voltages coupled by the FET internal capacitances from taking the output pin more than a Schottky diode drop below ground. Large negative transients can cause instabilities in the IC (LT1241 PWM controller) because the parasitic diode in the output transistor and substrate will be turned on.”
So Howcome not all SMPS's have this diode there?
To collaborate
