Diode forward/reverse resistance measurement
vinodquilon
Full Member level 3
Full Member level 3
See the diagram attached herewith.
What would the mulmeter shows if I connect a multimeter accross
A & B in resistance mode ?
DFR-Diode Forward Resistane
DRR- Diode Reverse Resitance
Both are identical diodes and the multimeter is set in auto range.
Practically, it will be near infinity in both cases.
It will show infinity most probably (while you don't touch the multimeter terminals)....
