Onedust
Junior Member level 2
I have a question regarding dimension tolerances, which are given by manufacturers. For example this ceramic capacitor: https://www.mouser.com/catalog/catalogusd/646/1018.pdf . The one I choose is 0603 in imperial. The tolerances for the Length and Width are +/- 0.1mm. The lead width is 0.35mm +/- 0.25mm. it's about 70% tolerance. Since I'm designing my first PCB, I don't have much experience with it.
Can someone explain to me if I should take exactly 0.35 mm or better to take larger width? Should I add to overall length i.e 1.6mm + 0.1mm?
best regards
den
best regards
den
