randika
Junior Member level 1
tachometer schematic
Hi all.
I'm new to this list and I'm an 2nd year EE engineering undergraduate.
I'm building a tachometer for a project in the university.
I need some schematics which generate a pulse after receiving an IR beam.
I'm planning to generate the pulse as follows...
1 > stick an IR reflecting piece of tape on the rotating shaft
2 > sending a continous IR beam using an IR led
3 > receiving the reflected IR beam generating a pulse
then
4 > measuring the time between pulses
5 > calculating the RPM
Is my plan correct..
If u've got some schematics for this the please send me.
Thanks,
cya
Randika K
Hi all.
then
Thanks,
cya
Randika K
