DIGITAL RPM WITH MIKROCONTROLLER
linoko
Member level 2
Member level 2
pic rpm meter
Hi friends,
This is my new project called Digital RPM meter
Enjoy it
rpm meter circuit
Hi friends,
here i'm upload the schematic and PCB of the RPM meter
Enjoy
Reactions: rayaposs
    V
    rayaposs
rpm pic
Which language do you use? Can you send the source code?
digital rpm meter schematic
linoko,
what program to open DDB file???
rpm meter project
can you give more detail on the project so that i can make up my mind before experimenting
pic rpm
Hi friends,
My project is rotation per minute meter, it will be helpful to all that don't have a tachometer on the instrumental board in your car.
To rx5 the DDB file you will open it with PROTEL 99.
here is the scheme of connection of my device to my old Renault 19 chamade car
    V
car rpm meter
Hi linoko,
can you convert the Protel scheme file into image file(bmp,jpg,gif,etc) or pdf??
I do not have protel program
picmicro rpm measurement
Here is the schematic
digital rpm meter circuit
i have one question this rpm meter must be connect to which part?
can you give me clear view for this application
thanks
rpm meter schematic
to ayammore:
Hi you may connect this RPM meter to any car. The place where you must connect is ignition coil see picture on top. Different cars have different ignition coils and you may find the place on your coil from where is output of tachosignal /tacho-implulses/ and connect RPM there.
rpm meter pic
linoko said:
to ayammore:
Wow thank you bro. I hv to check this out. :D
rpm meter
An interesting application will be to adapt it for both petrol & diesel cars. Since there is no ignition coil in a diesel engine, maybe the alternator can be a source for the input pulses. Since the alternator is used in both petrol & diesel vehicles, a common design can serve both.
cheers
pic16f84 rpm measurement
linoko said:
Hi friends,
Enjoy it
Can I get ur files.asm for digital RPM meter
8051 based rpm meter
Hi
I want to RPM meter for my step motor but i have no tacometer how i can adapt my system. At the other hand i have TTL output but if i connect to TTL output to tacho input directly, the LCD shows 0 rpm.
rpm meter using ttl ic
what is the best method to measure RMP, through a single sensor.
if we try to wait for one minut and count pulse, then it will show good accuracy but to late response.
or if we count for chorter time say five second and then multiply the couted pulses by 12, this will increase error.
so any one have other solution of this problem?
any algorithm??
help will be highly appriciated.
regrads
rpm com pic
thank´s
i need software in assembler(.ASM CODE) please
i not work in c++
very very thank´s:D
digital rpm meter project
can u provide the source code....for learning hex file dosen't provide help
microcontroller based digital rpm meter circuit
hii..
can u send source code in .c file?
pic based rpm meter
Here is a similar project kit from "www.united77.com/projects.htm" designed with Atmel 89C2051 as the heart of the circuit. The Microcontroller based Tacho meter is an easy-to-make photoelectric based tachometer project for measuring the RPM (revolution per minute) of rotating shaft, shop-floor tools and many household machines without any mechanical or electrical interface. The circuit employs AT89C2051 microcontroller as the main controller. Some of the major components used in the circuit are CA3140 operational amplifier, ULN2003 current buffer and KLQ564 4-digit, 7-segment display. Good luck.
