Digital questions....can anyone solve these?
vlsitechnology
Full Member level 5
Full Member level 5
1) Design a circuit which will either substract x from y or y from x, depending on the value of a .If a=1, the output should be x-y, and if a=0, the output should be y-x.Use a 4 bit substractor and two 4bit 2to 1 mux?
2) Realize a full adder using a 3 to 8 line decoder and a)two or gates b)two norgates
I will try to describe the solution for you because i did not have aready file to be downloaded.
The first multiplexer has inputs as (first four lines for x x3,x2,x1,x0) (second four lines for y y3,y2,y1,y0 ) respectively the selector connected to input a. the output of this mux is A A3,A2,A1,A0 which will be directed to the positive number of the subtractor circuit {remember to put the subtractor circuit to subtraction mode)
Thesecond multiplexer has inputs reversed as (first four lines for y y3,y2,y1,y0 ) (second four lines for x x3,x2,x1,x0 ) respectively the selector connected to input a. the output of this mux is B B3,B2,B1,B0 which will be directed to the Negative side or number of the subtractor circuit.
So it is done through your multiplexer depends on a multiplexer control signal select a.
Rashad
Added after 18 minutes:
For the second question:
the 3 to 8 decoder will have a three inputs A,B, Cin remember that Cin is the LSB and A is the MSB. then outputs will be eight lines 0,1,2,3,4,5,6,7
if you construct a truth table for the full adder circuit you will have:
A B Cin Sum Carry
0 0 0 0 0
0 0 1 1 0
0 1 0 1 0
0 1 1 0 1
1 0 0 1 0
1 0 1 0 1
1 1 0 0 1
1 1 1 1 1
now do the following for Sum find the lines for logic 1 and connect them through OR gate so lines 1,2,4,7 conected through OR gate for output SUM and lines 3,5,6,7 are to be connected to Carry output using OR gate.
Regarding Using NOR , I did not understand the reason for doing that. so can you explain why?
Added after 2 minutes:
I need points for downloading a file if you can help.
thank you
Can u please explain me y ur using 1,2,4,7 for ouput sum...and 3567 for output carry.........I am slightly getting confused...
Reply me
for question1
1:solution
big = (a) ? x : y;
small = (a)? y : x;
result = big - small;
2:solution
result1 = x - y;
reslut2 = y - x;
result = (a) ? result1 : result2;
1,2 complie results are different.
For this question , the numbers are the output of the decoders and usually numbered as 0 to 7 where output 0 will be either actve high or low when input ABC =000 and output 7 is actve when ABC=111. I don't know if you have a good background about decoders but any book in digital will help.
Regards
sory for replying late to your question
