Digital Potentiometer
saeed_pk
Full Member level 4
Full Member level 4
Islamabad, Pakistan
tablet mouse schematic
We change the resistance in a potentiometer mechanically.
I want to design a digital potentiometer(variable Resistor) whcose Resistance can be changed by just using different combination
Let say i have 2 bits then 4 combination so it covers total value of that potentiometer
Is there something like that exist if yes plz tell.
ssm2160 schematic
There are lots of these around.
Google for "digital potentiometer"
potentiometer digital maxim simulate proteus
hi
checkout proteus vsm www.labcenter.co.uk
and download vsmlibs archives
there are a few made in it also some dlls to add in
for maxim type's i add to this dll if people need a model
just let me know
try out devices like ad8403
this one takes a 10bit data word and the upper two bits select the pot to address
with the lower 8bit value
i vsmlibs archive is some test designs with micros you can try out
digital potentiometer mouse
I want circuit for volume dac
digital potentionmeter schematic
ssm2160 or 2163 easy to use using micro p to address it
or lots of them on a bus and in cascade
take a look at an old pipedream i had {and actualy half built}
then reused
its an old design now made using proteus lite
its not for simulation just a schematic of a wonderfull tablet mouse driven 4 channel 4 decks etc +other i/o dj mixer
you can download the demo of proteus pro
and use goto sheet to see all the sheets in the design
the implimentation in electrical terms of there use is ok
as is the ad8403 but no code was constructed atall
however its easy tomake one in c picc or something
a 40mhz chip will run it pic18f or something
circuit below authors home pages
hello
I want circuit for volume with ad8403
thanks
