Diesel88
I have a digital Volt / Amp meter rated: Operating voltage: DC 4.5 ~ 30V, Measure voltage: DC 0 ~ 100V, Measure current: 100A (require external shunt), Operating current: <20mA.
This meter has a Black / Red wires for the 4.5 – 30VDC power to the meter and 3 wires Red / Black / Yellow to connect to the load. The meter came with a shunt but it says if my measured amps are 10 or less, the shunt is not required
I want to measure the output volts / amps of a power supply unit, 120VAC input, and 36VDC / 9.7A output.
No problem to connect the power to the meter, I see the volts but I see 0 Amps because I don’t know how / where to connect the 3 wires
Any help would be appreciated
Thanks
Thanks
