Digital electronics sd card
pravesh95
Newbie level 2
Newbie level 2
How micro sd card store data.......
Means internal chip funda....of sd card....
It has flash memory chip(just like EEPROM). It has memory cells which are made up of floating(coated with electrical insulators) gate transistors. These cells have value of either 1 or 0 depending on voltage (like 5v=1 and 0v=0). In this way all cells are assigned values and binary code is made. This is how it stores data.
microSD is a kind of removable flash memory card used for storing information. SD is an abbreviation of Secure Digital. An SD card is a solid-state device. This means it has no moving parts in order to function. Inside the SD card is circuitry that includes flash memory. Flash memory is a type of EEPROM chip as mentioned in #2. It has a grid of columns and rows with a cell that has two transistors at each intersection. The two transistors are separated from each other by a thin oxide layer. One of the transistors is known as a floating gate, and the other one is the control gate. The floating gate's only link to the row, or wordline, is through the control gate.
