_gmd_
Newbie level 2
digital ammeter circuit
Following problem:
I have some digital ammeters with ICs and they require the shunt to be mounted in the ground line. Wont work in plus line. When I have the + voltage on the Analogue Input the ammeter will not work and blow something up.
How can I convert the +12V signal against ground to the 0V signal required with the shunt in the + line. An analogue meter will work no problem .. the voltage between the shunt points is 0-80mV. With the shunt in ground line it works no problem.
Anybody has a little circuit to convert the input signal ??
thanks
gmd
Following problem:
thanks
gmd
