Diffrent colors to shapes
maormat4
Junior Member level 3
Hello
I am using allegro and i want to color every place bound top shape in a diffrent color in my board. How can i do that?
And when im using 3D view and select model colors i get all the components in black, how do i change that?
And one more question, I have SLDPRT files for 3d view, how do i use it?
Thank you
You may assign color to components in 2D mode itself as you desired. While changing that to 3D, you will get.
For better view in 3D use altium.
You have to assign colors to net rather then to components by using this "Color" tab. You can select different colors for each nets from "Option" window.
For 3D view check View>>Dynaimc Layer Visibility in 3D viewer
Read the query first and give your answers. Don't mislead.
Actually @maormat4 asked about the place bound top. I think it related to the component rather than nets.
