Current used to charge up the parasitic capacitance of transmission lines to logic 1 and then discharge it to a logic 0, must pass through the lead inductance of the IC power leads. These current transients develop voltage spikes across the lead inductances. These voltage spikes drive the internal power rails away from their respective values on the PCB. These voltage spikes appear on every signal lead connected to the IC. Vcc and Ground bounce are caused by switching transients. They appear due to high package lead inductances or inadequate power system decoupling or both. Worst case Vcc and Ground bounce occurs when all members of the largest bus switch from one logic state to the other simultaneously.
