ismu
Full Member level 2
I am already designed Cloack by using PIC16F72 , but here am not using RTC chip ,instaed of that am using 32.768Khz X-tell to the Timer[Which will work on sleep] and when power failure happend then Chip[ will go to Sleep mode , But problem is After one month Time variation is there [2min] . So if am using DS1307 RTC chip , Can i remove this error? if yes how its happening? , because same X- tell is using in both designing.
