styojm
Hi All
I'm suffering from offset problem in my differentiator. The design is pretty standard
Where Rs=100 Ohm, C=1uF, R is a potentiometer with maximum of 20 kOhm, Cf=10nF, and the Op Amp I'm using OP27G from Analog. So when I change the potentiometer R, even if I ground the input, I still see a constant output voltage Vo that increase as R increase. If R=0 and Vo=0, then when R=20k Vo increases to about 10mV. Could anyone help me out with this? Cause I'm pretty confused about this drift and there seems nothing valuable I could find on google. Thanks.
