Yes, if your FPGA family support differential I/O-standards, e.g. LVDS. Review the online help or user manual of your design tool how to specify differntial pins in IO constraints,
There seems to be a fundamental difference between Altera and Xilinx about differential I/O.
In Altera, you can have a single-ended port in the top level entity and tell the place&route tools that it should be mapped to a differential transmitter/receiver.
I Xilinx, you must have both the '+' and the '-' signals as ports in the top level entity and connect them to a differential transmitter/receiver in your source code.
If you are using lattice (i have used ECP2), then no need to map the pin_n and pin_p separately.
Means in your top design module, you need to consider only one port (positive), then in the *.lpf you need to mention that the port is LVDS.
Then automatically the negative pin will assign the inverted value.
For lvds i think LVDS25 (2.5V), LVDS33(3.3V), etc are there, you can chose what you need (Depends upon the frequency of operation)
